I have two line datasets. Dataset A was created by using the snipper on dataset B (attributes BeginMeasure and EndMeasure), resulting in 15 segments in dataset A. They are both saved in SDE. Now I want to use the LineOnLineOverlayer to segment dataset B (only 1 segment before segmentation). I would expect that there will be 15 segments with _overlap = 2, and attributes from dataset A at each segment. Except that is not what is happening. There are only 10 segments with _overlap = 2, the rest are 1, which indicates that the two datasets do not overlap completely which is weird since A was created by B. I'm attaching the ffs for each dataset as well as the result ffs. What is going on and how do I fix?
Best answer by erik_jan
