Hi, I have to convert a .csv file to o .Las file.
Best answer by takashi
View originalHi, I have to convert a .csv file to o .Las file.
View originalIf your CSV table contains x, y, z, and other point cloud components, consider using the Point Cloud XYZ reader to read the table as a point cloud feature. Once you read the table as a point cloud, you can then write it into a LAS file with the LAS writer.
