I have few handful of workspaces (consuming job submit and data download services) that are initially setup without any email notification. Is there a way to modify the published workspace in FMW server to setup with email notification upon job submit fail and donwload fail?
When you publish a new service and setup email notifications while assigning the services, it works!! But i want to change the settings for existing workspaces.
Thanks in advance!
Hi, @udayburrey – this is a great question and thank you for posting it! If you are referring to changing the Post to Topic(s) upon Success/Failure, there is currently no workaround available save for republishing the workspace. I can definitely understand the inconvenience here!
This would be great to track as an idea in our Knowledge Center – safe.com/ideas – if you would be willing to create one. (I performed a quick search and didn't find anything that matched this request.)
There is a way to set a workspace property using the original REST API:
http://fmeserver/fmerest/repositories/<repository>/<workspace>/properties.json?token=<token>&category=fmejobsubmitter_FMEUSERPROPDATA&name=FAILURE_TOPICS&value=<topic>
You'll have to use either fmejobsubmitter_FMEUSERPROPDATA or fmedatadownload_FMEUSERPROPDATA depending on the service you workspace is registered to.
You can look at this question for more details.
Thank you @RylanAtSafe
I will plan on republishing the workspace. I will also create idea in the Knowledge center
Thank you @MattAtSafe
The workspaces are pretty much busy in the daytime. I will plan on doing it after business hours. The idea of stopping the engine service sounds great!
When attempting to download workbench, I get json instead 2 Answers
Notification management / IMAP Protocol 1 Answer
Amazon S3 downloader does not work while first run and succeed only while the second run 4 Answers
Multiple Email via Notification 1 Answer
Is it possible to use Email Template Keywords with FMEServerEmailGenerator? 1 Answer
