I have my parameter values in a SQLite table. I am able to access each value though a Python scripted parameter that opens the table and retrieves the value. However, this means that I have to open and close the SQL table one time for each parameter. Is there a way to make multiple parameters that can be read by the readers and transformers, perhaps in the Python startup script?
Best answer by takashi
