Dears FME comunnity members.
I've a cloud of point with ID and a type (Start/end) along a linear.
I would like to make a dynamic segmentation for keep cut lines between two points with same ID and different types.
The aim is to extract linear concerns by two points and exclude other linears.
You can see an explication of my problem with a draw in attachment.
Thank you very much for your help.
