Hey, i use an Attribute Remover to get rid of Attributes i dont need. Although, when i use a User Parameter to declare what Attributes to remove it doesnt work. If i preselect them in the Parameter Editor of the Transformer it does. Any ideas?
Hi @takashi,
Could you let me know which version of FME you have tested. When I checked in FME 2017.0.1.0 Build 17288, it is deleting the attribute when I pass one attribute but if I pass more than 1 then it is not deleting...
I have attached workbench which I tested. I received both Step-1 and Step-2 results are same
Pratap
Hi @andi_kraus, probably you encountered this situation.
However, the user parameter setting works fine. In the example above, the attributes "a", "b", and "c" will be removed definitely at runtime, even though the attribute names are still shown on the Canvas.
I think it's a limitation of the current Workbench that the setting of a user parameter linked to a transformer parameter won't be reflected to the user interface of the transformer.
Have you maintained the same case as attribute is present?
I mean parameter should be defined as per the case sensitive i.e. "attributename" or "Attributename"
