I'm using an XMLXQueryExploder to do some querying.
When I read in the file as published parameter, it adds 'D:\\FME Server\\repositories\\' prior to the full UNC path for no reason I can see. It also sometimes does it if I don't use a parameter.
Any ideas why it might be doing this?
It may be something obvious but can't work it out.
