Can someone please explain how I can capture the Errors in the log file created by FME Server using Python. From what I have read I am still not sure if the python has to go in the startup, shutdown or PythonCaller transformer to capture any errors while it is running. I am also not a python developer so would appreciate a full working script or an example Workspace if possible? I am using FME 2016.
Hi @takashi Thanks for the above, I will use the python method you suggested as the startup & shutdown scripts work fine. How do I write the error messages into an Oracle table?
Hi @takashi, I forgot to mention that I need to write the errors into an Oracle table but I am not sure how I could do this until I get some example output data. Also, as I had in another question, the LogMessageStreamer was what I was trying to use but found it difficult to get it to run at the end of the script to capture all the errors.
Hi @johnm, this Shutdown Python Script collects all lines containing "|ERROR" from the log file and save them as a list called "errors".
# Shutdown Python Script Example # Collect error lines from the log file. import fme errors = [] with open(fme.logFileName, 'r') as f: errors = [line for line in f.readlines() if 0 <= line.find('|ERROR')]
Then, what do you want to do using the error lines? For example, if you want to overwrite the log file with only the error lines collected, add these lines after the script above.
# Overwrite the log file with only the error lines if there were one or more error lines. if 0 < len(errors): with open(fme.logFileName, 'w') as f: f.writelines(errors)
# Startup Python Script # Add a function that collects error messages to FME Log File module. import fmeobjects errors = [] def errorCollector(sevirity, message): if sevirity == fmeobjects.FME_ERROR: errors.append('%s\n' % message) fmeobjects.FMELogFile().setCallBack(errorCollector)
# Shutdown Python Script # Do something using the collected error messages. # e.g. overwrite the log file with the error messages if there were one or more errors. import fme if 0 < len(errors): with open(fme.logFileName, 'w') as f: f.writelines(errors)
ArcPy on FME server 2 Answers
FME Server using SQLExecutor and PythonCaller 2 Answers
Python import error 1 Answer
How can I upload zipped-up file geodatabase to FME Server and kick off a workspace using Python? 2 Answers
How to write a python script to log FME error to the database if the FME Workspace fails? 1 Answer
