Bulk copying particular files from a folder using an Excel list
  • 6 November 2017
  • 30 views
Hello, I've tried looking into this and I'm pretty sure I know the readers and writers to use but the middle bit seems to be stumping me.
Put simply, I have a folder with 800 files in it.
I have a list of about 200 files which reside within the aforementioned folder.
I'd like to copy and paste only the files contained within the list into a new folder.
Any help would be greatly appreciated!
Badge +22
Read in the list (excel reader), do whatever manipulation required (attributeRenamer, attributeCreator, etc) to end up with an attribute called filecopy_source_dataset that contains the full path to the file to be copied. Send that to a filecopy writer that has the Destination File Copy Folder parameter set to the new folder.
