I am trying to create 3d block of the point cloud extents and not really getting anywhere. I was wondering if anyone would be able to help me in achieving this
Sam
Best answer by redgeographics
View originalI am trying to create 3d block of the point cloud extents and not really getting anywhere. I was wondering if anyone would be able to help me in achieving this
Sam
View originalYou can use a PointCloudPropertyExtractor to get the min/max x,y and z values. Then a 2DBoxReplacer to create the 2D bounding box from the min/max x and y, a 3DForcer to set that to the min z value and an Extruder to extrude it to max z - min z
Hope this helps.
Hope this helps.
That's does the job perfect thanks! How would I go about using this with multiple files for the input to create one dgn file that has all these individual blocks in?
Hope this helps.
Hope this helps.
