Hey Folks,
I created a working fmw on desktop, executes fine on desktop, fails on server.
notes
the fmw has the following logic
however in the log, it fails because of the following (image below).
my understanding is it only should use a BASIC/ARCVIEW license for the File Geodb format. however not sure what is happening here. perhaps it has to do with the user level running the engine? no clue.
Hi @dfresh,
I suspect that the user that is being used to run the FME Engine may not have permission to access the ArcGIS License. Here is a good article that explains this: https://knowledge.safe.com/articles/24153/using-fme-server-with-esri-software.html
Try what is suggested in the "FME Engine Service Account Requirements" section.
Also, ensure that you are using both 64bit FME/Esri or 32bit FME/Esri products as mixing these will not work. Hope that helps!
Unable to read SHAPE file 2 Answers
Datadownload without writer 3 Answers
How do you setup Directory Watch for folders on your local shared server. 2 Answers
FME server 202 header datastreaming 1 Answer
