Useing FME desktop Can i read and write "HKEY_CURRENT_USER" data ?
I need Created the key at run time and set the value according i will read the parameter values.
Best answer by brianatsafe
View originalUseing FME desktop Can i read and write "HKEY_CURRENT_USER" data ?
View originalHi @kumarc,
You can use a python library with the PythonCaller to do this. For example, the WinReg Module has tools to access and edit the Windows Registry.
See:
https://docs.python.org/2/library/_winreg.html#module-_winreg
