A customer requests a nation wide set of themes to be "cookie-cut" into separate municipalities. Each municipality should have a complete set of themes in its own sub folder.
I'm using a dynamic output to TAB, with Table name set to:
(A)Value(MUNICODE)\(A)Value(fme_feature_type)
But FME just substitutes the "\" (and "/") with an underscore, so all tables end up in the same folder.
Is there a way to tell FME to create the sub folders and put data into these ?
Cheers
The tablename corresponds to the filename, that's why FME won't allow slashes.
You can specify the output directory in the "fanout dataset" settings in the Navigator.
