My customer asked me about the difference between Esri Legacy SDE and Esri Geodb ArcSDE, when he wants to Reader SDE.
Danilo
Best answer by david_r
View originalHi,
Danilo
View originalHi, the legacy SDE format uses a C API that Esri no longer supports; in other words use at your own risk. The GeoDB SDE format uses an ArcObjects based API that is supported.
Thanks your reply and answer with this case.
Danilo
Also note that the Legacy SDE (called SDE30 internally) reader/writer has some particular limitations, search for "SDE30" on this page for more information:
https://knowledge.safe.com/articles/19440/comparison-of-fme-readers-and-writers-for-sde-and.html
On the flip side, in some instances it can be quite a lot faster than corresponding the ArcObjects readers/writers.
Many thanks your link sent me. I'll check it.
Danilo
