FME Server 2016 and earlier have a setting for SECURITY_SUPERUSER_ROLE. The superuser has some permissions that you cannot give to other users, such as doing a backup / restore. Does FME Server 2017 have this concept? I don't see SECURITY_SUPERUSER_ROLE in the config files.
It looks like the admin user is the default superuser, is that correct? If so, is it possible to grant other users the superuser powers? I would like to assign the superuser to an Active Directory group but can't figure out how to do that, even when logged in as the admin superuser.
Best answer by danilo_fme
