Creating a circle through all vertices of a triangle
  • 19 September 2017
  • 7 replies
  • 13 views
Hi All,
How would I go about creating a circle where the perimeter passes through all three vertices of a triangle?
I've attempted to use the Minimum Spanning Circle Replacer, but this creates a circle based only on the longest side of the triangle.
Any ideas would be greatly appreciated.
This might help:
http://paulbourke.net/geometry/circlesphere/
Scroll down to "Equation of a Circle from 3 Points"
Badge +22
Edit: This deals with the edge cases where two points are aligned vertically, two or more points are coincident and if there is anything other than 3 points
circlefrom3points.fmw
Userlevel 3
I would try this with a PythonCaller.
# PythonCaller Script Example
# Replace feature's geometry with a circle created from its first three vertices.
# Assume the input feature has a geometry having three or more vertices.
# The three vertices should have different coordinates, and any one of them
# should not be on the straight line passing other two vertices.
import fmeobjects
def createCircleFromThreeVertices(feature):
    coords = feature.getAllCoordinates()
    threeVertices = [fmeobjects.FMEPoint(*p) for p in coords[:3]]
    arc = fmeobjects.FMEArc(tuple(threeVertices))
    arc.setSweepAngle(360)
    feature.setGeometry(fmeobjects.FMEEllipse(arc))
This worked perfectly, thank you!
import fmeobjects
Elegant and minimal, I like it. The PythonCaller might also be followed by an ArcStroker if the destination doesn't support arcs.
import fmeobjects
This worked great for generating closed arcs (circles) but in attempting to output arcs with a start/end point and changing the sweep angle value it always returns a closed arc having the same start/end point.  Its as if the arc.setSweepAngle(x) statement is ignored?  What am I missing?
import fmeobjects
def createArcFromTwoVertices(feature):
    twoVertices = [fmeobjects.FMEPoint(*p) for p in coords[:2]]
    arc = fmeobjects.FMEArc(tuple(twoVertices),rad,False)
    arc.setSweepAngle(sweep_angle)
Userlevel 4
Badge +13
import fmeobjects
Hi @wallace You can create an Arc by 3 Points without Python, using an FMEFunctionCaller:
@Geometry(SET_PROPERTIES, ARC3POINTS,
      [<startX>], [<startY>], [<startZ>],
      [<midX>], [<midY>], [<midZ>],
      [<endX>], [<endY>], [<endZ>])
