I want to output a list from JSON using the PythonCaller.
I have tried the following syntax but it doesn't work.
info = json.loads(data)
for item in info:
feature.setAttribute("_list{}.value",item["time"])
Does anyone have any suggestions?
I am using FME Desktop 2017.0
Thank you
Hi @aquamarine,
If you want to do this in Python (presuming that "info" is a list of dicts, but not a dict itself!), you have to set each list attribute individually, like so:
info = json.loads(data) num_items = len(info) for i in range(num_items): time = info[i]["time"] feature.setAttribute("_list{{{}}}.value".format(i), item["time"])
Because Python's format() function replaces curly braces with function parameters, but FME needs these curly braces so it knows it's a list, you'll have to do e.g. "_list{{{}}}".format(3) which will return _list{3}.
But if your JSON input string comes from an FME attribute and you only need to explode it into a list, I'd recommend @takashi's approach and not use any Python at all, but to resort to transformers like the JSONFlattener (which is probably the one you need!), JSONExtractor and JSONFragmenter. Much cleaner.
PythonCaller input loop 2 Answers
Transfer python dictionnary between 2 Transformers 3 Answers
Failed to create unique list Python 2 Answers
Python setAttribute list of dict attributes 3 Answers
Where do I install python 3.6 packages to FME 2018? 2 Answers
