Hi @imran
this screenshot is from FME 2015 build 15538:
Do you have Open Advanced Browser button in your Add Reader dialog? It is only get enabled after you select the source format. If you click the Open Advanced Browser button, do you have Add Folder button? Could you please attach screenshots with your Add Reader and Advanced Browser windows?
Thank you!
Hi Imran,
Try using a * in your file name, like this:
The easiest way to do this is to select a single dgn file within the desired directory. Then select the name of the DGN from the parameter value and replace it with *. Make sure you leave .dgn at the end of the path.
-Courtney
How to validate Microstation file version 2 Answers
Reading MicroStation V7 custom line styles 4 Answers
dgn to dgn with tags 7 Answers
DGNStyler Cell Color 10 Answers
Microstation Tag Color and Font 2 Answers
