I have a workspace with a single 3D model (a tree) and a point dataset of several thousand points. Is it possible to replicate the 3D model and geo-reference it for every point?
Best answer by takashi
View originalI have a workspace with a single 3D model (a tree) and a point dataset of several thousand points. Is it possible to replicate the 3D model and geo-reference it for every point?
View originalHi @proudgis, a possible way I can think of is:
Another approach. This workflow would also be possible.
hi Takashi!
The format of the feature merger seems to have changed a bit since 2017, but for the most part it seems to work (testing it now). Do you know if there is a way to 1) randomly rotate the points and 2) draw the trees at different sizes/scales based on a height attribute in points?
thanks much
