Reading a Google Map from Map's URL
I have the following map:
https://www.google.com/maps/d/viewer?mid=1mtB5peL8y8Xc0aj85d5OMZX-sFs
Where I would like to use FME to read directly (online) from the map and extract out the desired pieces of information to publish in our Open Data Catalogue.
Everything I have found suggests to export to a KML file but that requires manual intervention and I want this as an automated process.
I am open to suggestions.
Thank you
Best answer by gerhardatsafe
Hi @billnjarheim
You should be able to use the URL that is used to export the KML (in your case: https://www.google.com/maps/d/kml?mid=1mtB5peL8y8Xc0aj85d5OMZX-sFs&forcekml;=1) in an HTTPCaller to download the KML to a file. Then you can read the KML file with a FeatureReader.
Hi @billnjarheim
danilo_fme
Forum|alt.badge.img+41
  • August 13, 2017
gerhardatsafe wrote:
Hi @billnjarheim
Good answer.
danilo_fme
  • August 13, 2017
Hi @billnjarheim, the @GerhardAtSafe sent you a perfect answer.
Just complemeting for the automate process to execute this Workspace, you can use the Schedule from FME Server.
Danilo
mygis
Forum|alt.badge.img+12
  • August 14, 2017
Hi @billnjarheim
Thanks @GerhardAtSafe
Hi @billnjarheim
@GerhardAtSafe Thank you.
Using your recommendation, I have proceeded onto the next step of my work. With the map URL that I had in my original post, there are different colored icons. The different colors represent that usability for that pay station; is there anyway to determine via the kml export the color of the icon? I have been exploring all of the format attributes and I have not found any that return the icon color (despite there being a number of color attribute options available).
I would take a look the Style & StyleMap feature types of the KML file. I think the styles and their relationship to the features are stored in there.
