What is the best tool/tools for concactenating (shp) results into a csv file?
  • 10 August 2017
  • 2 views
I am using FME(R) 2017.1.0.0. I have prepared a workflow consisting of several calculations and selecting attributes from SHP format. I want to output the results into a CSV format. More specifically, I want to transpose results into a custom format which automatically populate a spreadsheet. I am having trouble figuring out the right transformer/writers to transpose and design the spreadsheet the way I need to. I would appreciate this board's feedback.
Thanks in advance.
Badge +25
Is this the same issue as you're referring to in this question? If so, I'll see if I can merge them.
Thank you.
