max value of two attribute of a feature
  • 9 August 2017
  • 7 replies
  • 41 views
Badge +4
Hi !
I have a set of feature, for each feature, multiple attributes (A,B,C), all having numbers. I have to extract, for each feature, the maximum value value among the attributes A,B and C.
Since the StatisticCalculator limit to compute the max/min/... value of an attribute among all feature, how can archive my goal ?
thanks in advance !
Userlevel 2
Badge +16
Use the AttributeCreator transformer to create a new attribute MAX.
The value will be from the Arithmetic Editor using the function @max() as in the image, where each <FLOAT> is replaced by an attribute value.
Badge +26
Shouldn't that be 'max' instead of 'min'?
Userlevel 2
Badge +16
Too late, Hans. I saw it and changed the text.
Badge +4
thanks ! that's exactly what's I mean ! was sure that it was a simple way to get this result :)
Badge +3
@nmatton
the statistics calculator can calculate statistics (including max min) for all features, you can simply select them. It will add a prefix to each:
max_feature1,max_feature2 etc.
To get them in a single max attribute you would need to use a bulk attribute renamer with a regex
max_.+ => max
Badge +3
@nmatton
I see I misinterpreted the question....thanks for the demerit
If you don't want to have to click all the attributes in the max or min function, which is ...
The superior solution then is
Badge +4
@nmatton
That's very nice ! elegant and powerfull when having much more attributes. In my case it's limited to 2... but anyway, I love this way of thinking ! Thanks !
