SQLCreator/Executor question
  • 13 February 2015
  • 13 replies
  • 13 views
Badge +3
Hi again,
I use SQL cretors and executors a lot.
I have a slightly complexish sql query wich refuses to output.
The query is valid and works in SQL Developer as intended.
But it uses with statements wich has subselects in it as wel as grouping and aggregationfunctions.
Is this a limit to sql creator and executor i wonder.
For example the following script refuses output.
This will not yield output and no exposing of attributes:
 WITH vorming AS ( Select  vb.verblijfseenheid_id vbeenheid,                           vbs.omschrijving as sto,                           bj.bouwjaar as bouwjr                                               From    verblijfseenheid vb,                           verblijfsobjectstatus vbs,                           (SELECT   g.Gebouw_ID,                                     g.VLOEROPPERVLAK,                                     g.geometrie,                                     g.bouwjaar,                                     vg.verblijfseenheid_id,                                     vg.verblijfseenheidvolgnummer                               FROM  Gebouw g,                                     verblijfseenheid_gebouw vg                               WHERE g.bouwjaar = 2014        AND g.modification IS NULL                                   AND g.gebouw_id = vg.gebouw_id(+)                                   AND g.gebouwvolgnummer = vg.gebouwvolgnummer(+) ) bj                   Where   bj.verblijfseenheid_id = vb.verblijfseenheid_id                           AND vbs.status = vb.status_id                   ORDER BY vb.verblijfseenheid_id)                     SELECT vorming.bouwjr,vorming.vbeenheid,vorming.sto  FROM vorming;
 The inner part does output:
Are these transformers limited to like a single nestinglevel?
I have a much larger sql-queries wich i'd like to use. Is it possible, or am i missing something?
Tx in advance again.
have you tried to wrap the entire top query inside a SELECT statement? E.g.
SELECT * FROM (
  WITH...etc
David
Badge +3
Hi David,
I just tried your suggestion. It is still valid when run in SQL Developer and still yields correct result.
The SQL-Creator/executor runs, but does not output. Neither can i autoexpose the attributes. Manual adding them still yields no output.
I checked lot of my previous scripts, non of them go deeper then 1 nestinglevel. Might this by a limitation?
If so, then i must try restructure my script.
Tx for hlp
Gio
Userlevel 3
Hi Gio,
I succeeded to read data from MS SQL Server database through the SQLCreator/SQLExecutor with this query.
with tmp as (select Field1, Field2 from MyTable)
select * from tmp
FME 2014 SP5 and FME 2015.0
Although it's a simplified example, I don't think the fundamental structure is different from your SQL statement.
Perhaps there is a difference between Oracle and MS SQL Server?
Takashi
Userlevel 3
Oops! MS SQL Server threw an error if I added ORDER clause to the statement.
with tmp as (select Field1, Field2 from MyTable order by Field1)
select * from tmp
This statement is OK.
with tmp as (select top(100) percent Field1, Field2 from MyTable order by Field1)
select * from tmp
Userlevel 3
or
select * from tmp order by Field1
Badge +3
Hi all,
I see the "add a code sample" made my sql not fit in the box.
I don't think your example is similar Takashi.
You don't use a subselect wthin the with clause and you dont use aliases.
The is a subselect in the select with prefix bj.
Also my script uses aliases, so "vorming.bouwjr" is actually "vorming.bj.g.bouwjr"
If i only use inner part as i posted then it would be "bj.g.bouwjr". Inner part works.
Thats why i was wondering wether fme has limitations concerning this nesting.
Userlevel 3
This statement also worked with the SQLCreator/Executor.
with tmp as (select
    s.Field1 as newField1,
    t.FieldA2 as newField2,
    u.FieldC2 as newField3
    from
        MyTable s,
        MyTableA t,
        (select b.FieldB1, c.FieldC2
            from MyTableB b, MyTableC c
            where c.FieldC1 = b.FieldB1) u
    where
        t.FieldA1 = s.Field1
        and u.FieldB1 = s.Field1)
select tmp.newField1, tmp.newField2, tmp.newField3
from tmp
The differences from yours are:
(1) I'm using MS SQL Server (probably you are using Oracle).
(2) I didn't put ORDER clause in the WITH clause.
Can you see any other fundamental differences?
Badge +3
Yes, im a doing this in oracle. Oracle Spatial.
And apart from ordering i use analytical and listaggragegation functions.
I have flattened the query, but still SQL_creator/executor does not want to output.
Maybe it has something to do with the grouoing and partitioning functions.
I have differtent scripts with same structure as the one i posted, except they do not use grouping and partitoning functions.
All my sql run as intended in SQL Developer.
It starts to look as a fme limitation to me.
I just tested an SQLCreator on Oracle using a WITH-clause and it seems to work without a hitch. Granted, my query was a lot simpler than yours.
Also, I had to skip the ; at the end of the query to avoid a nasty error message from FME. Could that be the root of the problem here?
David
Badge +3
Hi, no the ";" at the end is because of my copy pasting from developer, i mostly remember to remove it..;)
It seems to be the analytical/stringaggregation functions that prevent teh output. This requires grouping etc.
Though i am not very sure about that. I have none of those working trhough the sql-creator/executor.
I have flattened the query, producing same result and it still does'nt budge in fme.
Here is a sample:
 WITH BJ2014 as(SELECT  DISTINCT          g.bouwjaar,         g.Gebouw_ID,         g.VLOEROPPERVLAK,         vb.verblijfseenheid_id         ,LISTAGG(vbs.omschrijving,',') WITHIN GROUP (ORDER BY vb.verblijfseenheid_id ) OVER(PARTITION BY vb.verblijfseenheid_id) as vormcyclus   FROM  gebouw g,         verblijfseenheid_gebouw vg,         verblijfseenheid vb,         verblijfsobjectstatus vbs   WHERE g.bouwjaar = 2014               AND g.modification IS NULL       AND g.gebouw_id = vg.gebouw_id(+)       AND g.gebouwvolgnummer = vg.gebouwvolgnummer(+)       AND vg.verblijfseenheid_id = vb.verblijfseenheid_id       AND vbs.status = vb.status_id       GROUP BY vb.verblijfseenheid_id,vbs.omschrijving,g.bouwjaar,g.Gebouw_ID,g.VLOEROPPERVLAK) SELECT geb.geometrie,        BJ2014.VLOEROPPERVLAK,        BJ2014.vormcyclus,        BJ2014.verblijfseenheid_id,        BJ2014.bouwjaar,        BJ2014.Gebouw_ID FROM   BJ2014, Gebouw geb WHERE geb.Gebouw_ID = BJ2014.Gebouw_ID  AND geb.modification IS NULL
the geometry can't be used in the statistical/analytical queries so it has to be backreferened in the query. This runs correctly using sql-developer.
It is about "stay-unit" wich have been "shaped" and or "taken in use"  in buildings buildt in 2014.
I like to use SQL-creators because it is much faster than using fme oracle readers. And i can parametrise entire sql-scripts and use attributes created in fme at runtime, wich is very cool. (though this can be tricky because everyone seems to use different flavors of regexp and sql syntaxes..)
I'm still fiddling with it. I may end up having to export result to file and read this file into fme (bwaah...)
How annoying...
I don't suppose you have the rights to create a (temporary) view in the database?
Or you could even use an Oracle global temporary table: http://oracle-base.com/articles/misc/temporary-tables.php
David
Badge +3
Hi all.
I finaly got it to work trough the SQL-Creator.
I had to add a alias to the selected attributes within the with statement to acces them. It was not possible to acces them otherwise. In Oracle, using SQL developer this is possible, in fme appearently not.
so following does work in fme SQL-Creator:
 WITH BJ2014 AS (SELECT  DISTINCT                          g.bouwjaar bj,                         g.Gebouw_ID gid,                         g.VLOEROPPERVLAK gop,                         vb.verblijfseenheid_id vbi                         ,LISTAGG(vbs.omschrijving,',') WITHIN GROUP (ORDER BY vb.verblijfseenheid_id ) OVER(PARTITION BY vb.verblijfseenheid_id)  vormcyclus                   FROM  gebouw g,                         verblijfseenheid_gebouw vg,                         verblijfseenheid vb,                         verblijfsobjectstatus vbs                   WHERE g.bouwjaar = 2014                                               AND g.modification IS NULL                       AND g.gebouw_id = vg.gebouw_id(+)                       AND g.gebouwvolgnummer = vg.gebouwvolgnummer(+)                       AND vg.verblijfseenheid_id = vb.verblijfseenheid_id                       AND vbs.status = vb.status_id                       GROUP BY vb.verblijfseenheid_id,vbs.omschrijving,g.bouwjaar,g.Gebouw_ID,g.VLOEROPPERVLAK) SELECT   BJ2014.vormcyclus         ,BJ2014.bj bouwjaar         ,BJ2014.gid Gebouw_id         ,BJ2014.gop Vloeroppervlak         ,BJ2014.vbi verblijfseenheid_id         ,geb.geometrie          FROM   BJ2014,gebouw geb WHERE  BJ2014.gid = Gebouw_ID  AND geb.modification IS NULL
As you can see i reinstate the orignal names in the final selection.
Userlevel 1
Badge +11
Hi @gio,
I'll take a look at this... we would expect if it can work in SQL Developer that it should work within FME.
A tip on autoexpose attributes...
in the "Populate from SQL Query" we don't handle very complicated queries (the query here can be manipulated/changed and doesn't affect the main query)... An easy Select statement from a single table and a simple where clause is handled well...
So sometimes simplifying the query can help get some of the attributes back and then manually add the rest.
