HI, i am hoping someone is able to help me.
I am building a html output and i am using the fanout expression to build individual html documents. My question is does the fanout expression need to have values from within the html content or can i use attributes from a attribute manager to set the fan out expression?
hope that makes sense
Hi @qmangaming The attributes used in your fanout expression don't have to be present inside the html content as long as every feature being sent to the writer has that attribute present on it.
HTML writer Fanout with fme_basename 2 Answers
Has anyone tried integrating Beautiful Soup with FME Desktop 2 Answers
How to extract URLs from HTML and create features? 3 Answers
Trigger email notification after TXT line writer completes? 1 Answer
Writing html string to an AGOL hosted feature layer 1 Answer
