I am trying to combine roughly 50 different GTFS feeds (a feed is composed of 13 CSV/txt files) into ArcSDE using the spatial ETL tool. I need to update the stop_id field in each of the csv text files to continue the stop_id sequence that of the agency table in the SDE. Basically i need to remove and match the Stop id from the incoming feed to the stop id sequence in the SDE. I am very new to spatial ETL i have only been using it one day so please bear with me if i am not making much sense as this is very new to me
Best answer by lars_de_vries
