Triple zipped XML
  • 22 February 2015
  • 8 views
Userlevel 4
Badge +13
Hi ppl,
My input are XML files that are triple zipped (zip in a zip in a zip) I know I can read from a zip file, but is there anyway to read from a triple zipped input?
If not does anybody have a tip on how to handle such a situation? ( any python/ tcl savy's advice?)
Cheers,
Itay
Best answer by takashi 23 February 2015, 07:49
Userlevel 3
Hi Itay, current FME seems not to have the capability to unzip recursively.
This example is from my old PythonCaller implementation. FYI.
import fmeobjects
import os, re, zipfile
class RecursiveUnzipper(object):
    def input(self, feature):
        def clearDirectory(path):
            if os.path.isdir(path):
                for t in ['%s/%s' % (path, s) for s in os.listdir(path)]:
                    clearDirectory(t)
                os.rmdir(path)
            else:
                os.remove(path)
        # Get zip file path and destinction directory path.
        zipPath = feature.getAttribute('_zip')
        outDir = feature.getAttribute('_out_dir')
        if os.path.exists(zipPath):
            # If specifid output directory exists, remove it beforehand.
            if os.path.exists(outDir):
                clearDirectory(outDir)
            self.index = 0
            self.unzip(feature, zipPath, outDir)
        self.pyoutput(feature)
    # Unzip recursively
    # Extracted file paths will be stored in a list called "_unzipped{}".
    def unzip(self, feature, path, outDir = None):
        if os.path.isfile(path):
            m = re.match(r'^(.+)\\.zip$', path, re.IGNORECASE)
            if m != None:
                zip = zipfile.ZipFile(path)
                if zip.testzip() == None:
                    dir = outDir if outDir else m.group(1)
                    zip.extractall(dir)
                    for t in ['%s/%s' % (dir, s) for s in os.listdir(dir)]:
                        self.unzip(feature, t)
            else:
                feature.setAttribute('_unzipped{%d}' % self.index, path)
                self.index += 1
        elif os.path.isdir(path):
Takashi
Userlevel 4
Badge +13
Hi Takashi,
Fantastic! thanks for your help.
Itay
