When invoking lmutil or lmgrd an error "no such file or directory" is returned.
Investigation yields that lmutil is using the following interpreter: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-lsb-x86-64.so.3, for GNU/Linux 2.6.9, stripped.
What can I do?
