Results from Oracle stored procedure
  • 2 April 2014
  • 22 views
Badge +1
Is there a way that I can get hold of and use the results from calling a stored procedure in a SQL Executor?
My procedure seems to run fine, but I haven't been able to get anything out of the Result output port of the SQLExecutor.  The stored proc queries a mapping table and returns either an existing id or a newly-created one (or an error).
My SQL looks something like this:
declare
  ID number;
  STATUS number;
  ERRMSG varchar2(128);
begin
  schema.get_new_id(@Value(obj_id),'@Value(table_name)',ID,STATUS,ERRMSG);
end;
Again, it seems to run fine, but I would like to use the output variables ID and STATUS on the feature farther along in the workflow (e.g. to set an attribute value).
Any assistance is appreciated.
Thanks!
does schema.get_new_id() have any return values? This is necessary. You cannot have return values in the anonymous block in your SQLExecutor (not supported by Oracle), so the function get_new_id() must RETURN the values ID and STATUS to you. Declaring the results as OUT isn't enough here, they must be explicitely returned, i.e. get_new_id() must be a function, not a procedure.
If you can modify the declaration of get_new_id() to RETURN the results, or eventually create a PL/SQL wrapper function around it to do it, you can then do something like this in your SQLExecutor:
select ID, STATUS, ERRMSG
from table(schema.get_new_id(@Value(obj_id),'@Value(table_name)'))
You can then expose the resulting ID, STATUS and ERRMSG as feature attributes in the SQLExecutor, as usual.
See also the example here (http://stackoverflow.com/a/9484311/370301).
David
See also the example here http://stackoverflow.com/a/9484311/370301
David
Badge +1
David - thanks for your response!  I don't have it solved yet, but this is helpful.
