I have an attribute that contains a string with ASCII control characters in it. I'd like to use the StringReplacer to either remove or replace those characters with something else. I see that I can select some characters (like the backspace character or the carriage return) from the Special Characters list inside FME's text editor, but the one I need isn't listed there. For example, the SOH (or start of heading) character is present in my data, but I can't match on it directly. What can I do to handle this?
Best answer by lauraatsafe
