Hi
Does anyone have a transformer or groups of transformers prebuilt to extract this 32°25'20.4"S 151°29'40.5"E 2145.1 to decimal degrees split into degrees minutes decimal seconds
yes i am lazy.....but pressed for time
Hi
Best answer by david_r
You can use a StringSearcher with the following regex to split the values:
(\d+\.?\d*)|([NSEW])
You'll have to set the "All matches list name" to something like _parts, which will be a list that will contain all the separate elements of your DMS string, e.g.:
`_parts{0}.match' has value `32'
`_parts{1}.match' has value `25'
`_parts{2}.match' has value `20.4'
`_parts{3}.match' has value `S'
`_parts{4}.match' has value `151'
`_parts{5}.match' has value `29'
`_parts{6}.match' has value `40.5'
`_parts{7}.match' has value `E'
`_parts{8}.match' has value `2145.1'
You can then feed the individual numbers into a DecimalDegreesCalculator, e.g.:
You may also want to use something like a TestFilter and a couple of ExpressionEvaluators for values that aren't situated in the north-eastern hemisphere.
