I have been using the PNGRASTER writer to do dataset fanout. But now I need to change this to a FeatureWriter, and I cannot find where on the form does one set the famout check box. The file names are comming in via a $RasterFileName attribute I created format "\\z\\x\\y.png" and the top level folder which these files should go into is $outDir (the raster files were created by running the WebMapTiler, so I don't want to lose the _num_tiles parameter, which I need to send . Thanks
I.e. I want to reproduce this sort of effect:
Best answer by takashi
