I write data using AutoCAD DWG/DXF writer. Everything works fine but after opening the file, users allways have to click "fit to view" (microstation) to see the data - and the ones that are not very familiar with microstation don't find the data at all.
Is there the possibility to write the data's extent to the file? Maybe by using one of the various autocad_... format attributes?
Thank you very much fot your help!
Simon
