Write 3D solids with tags to dgn
I'm trying to write tags to a dgn-file on 3D solids which i have generated in FME but no tags appear. It works fine if I use other geometry types i.e. igds_shape but then I do get a lot of features which I would like to avoid.
This message makes me want to ask if anybody out there has found a workaround:
DESIGN WRITER: Tag writing is currently not supported for the associated element
Best regards
Olof
Userlevel 1
Badge +21
I'm encountering the same issue
Userlevel 1
Badge +21
The associated element is an IFMEExtrusion btw, which seems to be the only igds_3d_solid that is supported
