Dear FME-users,
I’m creating polygons from input raster data. Therefore I use the transformer “RasterToPolygonCoercer”. The values of 7 input data are written in 1 output feature class.
These attributes includes a lot of “null-values”. (<NULL>)
Do you’ve any ideas which transformer can solve it?
Thank you very much and best regards.
Konrad
I’ve 7 input data with the same extension. It means that the values are different. Later I want to do queries for point coordinates (x, y). For this I need 7 values and not just 1 and 6 times “Not Null”.
Maybe I can create 7 single output files and set them in relation. But I don’t know how to do this.
I hope my description is understandable. If not I’ll try it again.
Thank you very much. :)
If you need to change all the null values to any specific value, I believe that the NullAttributeMapper transformer is the way to go.
I'm unclear what the "overlapping polygons" means. Could you please elaborate the requirement?
Do you've an idea how to fill the attribute values of the overlapping polygons?
I've added a screenshot, please take a look in the attachment.
Have you looked at the NullAttributeMapper?
