I am new to FME. I currently have 286 old gdb that consist of 15 feature classes, they needs to be updated to a new gdb. Some of the updates includes: changing a point to polygon, merging feature classes, changing fields name, and also mapping value for subtype. I have already figure out how to update an individual gdb.
Right now, I am playing around with Workspace runner and Directory and File pathnames reader. I am uncertain about some of the parameters.
In my workspace, for my reader and writer, does it matter if I load any old gdb as the reader? and any new gdb as the writer?
I have attached below what my current workspace looks like.
Can you please help me out? It would be very much appreciated :-)
Vincent
Hi @takashi, I am still unsure to what to put for the Dataset source parameter for the current workspace's reader. Right now I have it set to an individual old gdb directory.
Hi @vincentlaw94, you can use the Directory and File Pathnames (PATH) reader to read every *.gdb folder path in a specific folder, and pass them to the FGDB Source Dataset parameter of the current workspace through the WorkspaceRunner, one by one.
Regarding destination *.gdb path), consider using the Fanout Dataset functionality.
