There was an error processing your request COM.safe.fmeserver.api.FMEServerException: Unauthorized request by user demotoken due to lack of proper permissions.
Hi All
We have come across this error as well. We did some investigation found that it only happened to a few workbenches. These workbenchs had a parameter which was named "Token". Once this was renamed the workbench ran with no errors. Have a look in the workbench to see if there could be a reserved word as a named parameter that FMEServer may use.
