I would like to know if anyone has published a data source to Tableau Server from FME
FME has a Tableau .tde "extract" writer. Tableau recently, starting with v10.1.4, changed its extraction engine from .tde to .hyper "Hyper".
You can use FME to write the .tde file to a network directory or to a drive on the Tableau server.. Then setup a scheduled refresh to read from the .tde file. Although this will still work with .tde files for the moment... not sure how nice it will play as Tableau completely phases it out in favor of .hyper.
Here are some links that could be of your interest:
https://www.safe.com/solutions/tableau/
https://knowledge.safe.com/articles/37685/how-to-write-spatial-data-into-tableau-with-fme.html
https://blog.safe.com/2016/08/importing-spatial-data-tableau-using-fme/
And even a webinar:
http://www.safe.com/webinars/how-prep-mapping-data-tableau-become-geographic-viz-wiz/
Here are some custom transformers:
Can you specify the problem you face?
