How much free disk space do I need to install FME 2017?
Userlevel 2
Badge +16
I have installed FME 2017 Desktop and it takes close to 3GB of disk space.
Thanks. I only have a little more than that and I wasn't sure. Thought I'd check.
Badge +30
Me too. Almost 3 GB of disk space of my machine.
Badge +26
If you're limited on disk space I would strongly recommend putting the FME Temp data on a different drive, see this article for instructions on how to do that.
Ideally you want to have quite a bit of free space (my personal limit is 5 GB) even after installing FME, some translations can consume a lot of temporary disk space.
