I am running multiple workspaces that have the same published parameters that are passwords. Is there centralized way to store published parameter passwords that are used by multiple workspaces?
I can't find anything in the documentation about how to do this.
unfortunately this is not the case for published parameter even password type and they are quite easy to reveal.
There are several ways to accomplish that for example a centralized file containing passwords that is read via a startup python script.
I am sure other users have other ideas and experiences to share.
Hope this helps
What kind of passwords are you referring to.
If it is database connections, FME stores these in a connection file outside the FMW file.
They are references by connection name, so the username, password and database name are not stored in the FME file.
How can I script a connection parameter with python 3 Answers
Priority tag for jobs invoked via notification service 1 Answer
Varying Multiple Attachment Email Used to Trigger Workspace and Populate Publish Parameters 1 Answer
FME Server and Published Parameters 1 Answer
2018 fme server job submitter failing on user parameters. 4 Answers
