I have a file 'Road Segments' and as it implies each segment has a start and finish chainage. So for e.g. the first section of road might be 0start - 150m, the second section may be 150m - 250m and so on.
What I need to do is to give the chainage for somthing along the road. So there may be a culvert that crosses somewhere along segment 150m - 250m. I think I need to break these road segments into 5 m sections and use those 5 m sections as the chainage. Therefore Road Segment 150m - 250m would be broken into 155,200,205,210,215.......etc and if the culvert fell into the zone of say 210, then 210 would = the chainage for that culvert.
What transformers would you recommend to achieve this?
