Hi.
Im new to FME and this seems like a simple one.
I have an attribute called type and within it the following values
Floor:FLR1009
Slab:SLB2435
DOR-1000
WAL-2000
I want to remove the Floor: and the Slab:
Id rather use a string renamer if possible as the Floor: and Slab: will be constant.
Chris.
Best answer by takashi
