Why am I getting the above error on my system?
Why am I getting the error : Unable to load a library in the folder: C:\\Program Files\\ArcGIS\\Pro\\bin. The error number returned from GetLastError is: 127?
The above error can be caused by installing a newer version of ArcGIS, but without uninstalling the previous version's background geoprocessing. When installing a newer version of ArcGIS please ensure that when you uninstall the previous version, you also uninstall background geoprocessing. Installing the matching version of background geoprocessing for your new ArcGIS installation should resolve the issue.
Â
Very helpful, thanks!The above error can be caused by installing a newer version of ArcGIS, but without uninstalling the previous version's background geoprocessing. When installing a newer version of ArcGIS please ensure that when you uninstall the previous version, you also uninstall background geoprocessing. Installing the matching version of background geoprocessing for your new ArcGIS installation should resolve the issue.
I've also seen this error a few times recently when my network connection had dropped and as such FME could not connect to the ArcGIS licence server.
Thank you Annabelle! I tried re-installing FME and ArcGIS before finally coming here, and this was exactly my issue. When I upgraded ArcGIS last week I forgot to upgrade Background GP. All is working now!
