There are more arcs in there being procesed correctly.
It seems that particular objects is somehow flawed/affected.
I tried rebuilding it in Autocad. It consists almost exclusively of arcs, but so do some other parts.
Autocad coould not connect. So i reset the endpoints to try to fix it.
Still no dice.
I have found the problem tho...:)
That particular object is 2 hatches on top of eachother.
Remove 1 in your dwg.
I did and it works as supposed.
Gio
NetCDF to raster/ASCII 1 Answer
offsetcurvegenerator 0 Answers
DGN(V8) Writer, bug? 0 Answers
Oracle to shapefile 1 Answer
Translation tool log stops, tool hangs 0 Answers
