is it possible to transform e.g. shape-Files using the NTv2 - method and using an own data grid (ascii or binar) ?
Thanks for your answers
Isabell
Isabell
this is a bit outside of my domain, but take a look under the menu Tools / FME Options / Coordinate Systems. I believe you can double-click on the entries to specify the grid shift file(s) there.
David
yes it's possible to specify the grid files there. But where can I tell FME that it should use the NTv2-method instead of a 7-Parameter-transformation?
I normally use the FME Translator to reproject my shape files or the reprojector in FME workbench.
Regards
Isabell
that was exactly what I needed!
Thank you very much!
Isabell
