Best answer by davideagle
View originalMicrosoft Sharepoint
I've also seen this requirement very recently where a customer is planning a data migration from one document management system to Sharepoint. At the moment we are looking at what options there are to use FME to do this via the Sharepoint Web Service. There are 4 million documents to migrate, which is far too much for CTRL-X and CTRL-V!
Has anyone done this via FME?
Would a batch file in windows be easier to copy all the data up?
I'm not sure how a Sharepoint load works but, in general, to move/copy files use the Directory and File Pathnames reader (to get a list of files) and the File Copy writer (to move them).
Thanks for the suggestions all. This kind of file copy is not quite as simple as a standard directory file copy @Mark2AtSafe. A batch approach might be possible be we also need to do deduplication and update other file metadata, so want to try to get FME to do the job @marko. We have however got a proof of concept up and running with a lot of trial and error using the XMLTemplater and the SoapSender... so fingers crossed.
Hi @1spatialdave,
I'm looking to do the same thing. Are you able to share your workbench?
or describe your solution a little more detail?
I'm currently stuck with SP2010, so I think will need to use the copy.asmx web service somehow.
Nick
Hi Nick
For a quick reference, you can upload documents by sending a SOAP message to the CopyIntoItem method of copy.asmx.
I build up the SOAP message using XMLTemplater.An example ROOT Template:
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/">
<s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<CopyIntoItems xmlns="http://schemas.microsoft.com/sharepoint/soap/">
<SourceUrl>nothing</SourceUrl>
<DestinationUrls>
<string>$(SP_SITE){fme:get-attribute("SP_list_root_folder")}{fme:get-attribute("SP_path")}</string>
<string>$(SP_SITE){fme:get-attribute("SP_list_root_folder")}{fme:get-attribute("SP_path2")}</string>
</DestinationUrls>
<Fields>
<FieldInformation Type="Text" DisplayName="Surname" Value="Smith" />
<FieldInformation Type="DateTime" DisplayName="Date of Birth" Value="1965-11-03" />
</Fields>
<Stream>{fme:get-attribute("document_base64_encoded")}</Stream>
</CopyIntoItems>
</s:Body>
</s:Envelope>
$(SP_SITE) is an example for workspace parameter and {fme:get-attribute("SP_list_root_folder")} for an attribute.
There are 4 important bits:
- <DestinationUrls>
- <Stream>
base64 encoded content of the document. I could upload documents up to 40 MB. It is worth to restrict the size because large documents can make the workspace stall. - <Fields>
The contents of <SourceUrl> is indifferent but cannot be empty (I don't know why)
You can use the HTTPCaller transformer to send the message to the web service:
Request URL: protocol://yoursharepointserver/_vti_bin/copy.asmx
HTTP Method: POST
You need to add a header (SOAP method to call) in the Headers section :
Value: http://schemas.microsoft.com/sharepoint/soap/CopyIntoItems
In Body section:
Upload Data: Specify Upload Body
Upload Body: set the Result Attribute of the XMLTemplater
Content Type: text/xml
Base64 encoding the document content is quite easy:
- AttributeFileReader transformer: set the Source File Character Encoding to Binary (FME-binary)
- BinaryEncoder transformer: Encoding Type: Base64
I created a CSV with the document source file path, SharePoint URL and optionally metadata columns. that drive the upload.
In theory the workspace is straightforward: CSV reader -> AttributeFileReader -> BinaryEncoder -> XMLTemplater -> HTTPCaller -> AttributeRemover -> Inspector
There are a few possible problems: missing or unreadable source file, large file, invalid characters in filename (SharePoint is more restrictive than tile system), ...
Another thing, proper attribute display names and types:
Send a request to
Request URL: protocol://yoursharepointserver/_vti_bin/lists.asmx
Headers:
Value: http://schemas.microsoft.com/sharepoint/soap/GetList
Body:
<Envelope xmlns="http://schemas.xmlsoap.org/soap/envelope/">
<Body>
<GetList xmlns="http://schemas.microsoft.com/sharepoint/soap/">
<listName>$(SP_LIST_NAME)</listName>
</GetList>
</Body>
</Envelope>
The XML response will contain Type, DisplayName, .. of all attributes.
My workspaces are a bit specific and big but if there is any interest I can get rid of the unnecessary bits and upload.
Hope it helps.
Hi Nick
<DestinationUrls>
</DestinationUrls>
<Fields>
</Fields>
</CopyIntoItems>
</s:Body>
</s:Envelope>
- <DestinationUrls>
- <Stream>
HTTP Method: POST
In Body section:
Send a request to
Headers:
Body:
<Body>
</GetList>
</Body>
</Envelope>
Hope it helps.
I had most of it after discovering the wsdl endpoint, however i didn't have the SOAPAction header.
I do have a small bug where if i try to write a feature to a logger that includes my endocded doc, fme just stalls. remove to loggers, and it runs smoothly, very odd. I'm working in fme 2015.0, as i'm looking to deploy to that version of server, I suspect it'll be a bug that's fixed in 2016.
many thanks.
Nick
Just dropping an additional contribution to this thread should anyone find it. We're expecting a Sharepoint 'package' to land in the next few weeks from the good people at Safe that will include the ability to access formats supported by FME directly on Sharepoint via a web connection as well as a dedicated SharepointConnector Transformer. I believe there will be many very happy people 😀 .
