I have installed both ArcGIS Desktop and ArcGIS Engine to the same machine where I work with FME Desktop. I want FME to only use my ArcGIS Engine due to licensing constraints -- how can I do this?
Best answer by rylanatsafe
View originalI have installed both ArcGIS Desktop and ArcGIS Engine to the same machine where I work with FME Desktop. I want FME to only use my ArcGIS Engine due to licensing constraints -- how can I do this?
View originalWhen it comes time for FME Desktop to grab an Esri ArcGIS license, we follow a general principle of checking out the "highest license available" for any particular situation. As a result, this logic generally searches for products in the following order:
Please note that if an FME Desktop application is running, FME will favour checking out a license from an ArcGIS Desktop product (i.e. ArcGIS Desktop over ArcGIS Engine).
Thanks for this explanation! However in reality this does not seem to work that way. I have both ArcGIS Desktop and ArcGIS Pro installed. I noticed that FME 64bit automatically connects to the ArcGIS Pro license (both are 64bit), whilst FME 32bit automatically connects to the ArcGIS Desktop license (both are 32bit).
It would be nice if you could choose an available license. Perhaps as an option within the ArcGIS readers/writers it concerns, otherwise as an option in the Tools > FME Options.
I came to the conclusion after I posted my response that I forgot to do that. But still it would be nice if you could influence the license picked up by FME.
Please consider voting for this idea and adding any additional comments or suggestions!
Edit: Troubles with the hyperlink...? https://knowledge.safe.com/idea/37191/introduce-user-settings-for-arcgis-product-and-lic.html
Helpful information will include..
- Log Files identifying that the ArcGIS Pro license is consumed instead of ArcGIS Desktop when running a translation that uses an Esri format accessing ArcObjects (for example, GEODATABASE_FILE).
- The HTML output of the report attached to this Knowledge Center article.
I'm sorry for the inconvenience you are experiencing.
