Hi All,
I can download a file using the ftpcaller, but cannot work out if possible to download when the file is on higher level directory
ftp://172.30.227.2/../gisgroup/test.zip
Is this possible?
Best answer by david_r
View originalHi All,
Is this possible?
View originalIs this the URL you're using? If so, it will proably not work since you're trying to go on level up relative to the root.
This ought to work:
ftp://172.30.227.2/gisgroup/../test.zip
Which would be the equivalent to:
ftp://172.30.227.2/test.zip
This ought to work:
getting HTTP/FTP transfer error: 'Access denied to remote resource'
