is it possible to convert HTML page to jpg file.
Thank you, cheers.
Best answer by dmitribagh
View originalHi,
Thank you, cheers.
View originalI'm not sure FME is the best tool for that. However there are a lot of utilities out there specifically for this, you will find many of them if you google e.g. "convert html to image".
If necessary, you could probably automate such a tool using FME.
Hi @zzupljanin, I agree with @david_r on the issue, you could try to automate it via FME and PhantomJS
Good luck and have fun!
Hi @zzupljanin,
I suggest you take a look at the next website where you can download a command line tool to make the conversion. Using a SystemCaller you can call this tool via FME.
https://www.coolutils.com/HTML-JPG-CommandLine
Good Luck!
@zzupljanin
I made a custom transformer that turns HTMl into a raster using WKHTML2Image command line tool, I can publish later this week (and update this thread with the link).
I published a similar transformer that turns html into a PDF last week:
Hi @zzupljanin
Here is the transformer to convert HTML to images. Note that we only create a wrapper to call the tool within FME and have no control over the image creation.
https://hub.safe.com/transformers/html2imageconvertor
i tried phantomjs to get an image of an url. Well, it works perfektly when running the workbench via the "run"-button. but the SystemCaller fails to execute, when the Workbench is run from within a batchfile as a scheduled task.
Here is my setup for the SystemCaller...
Any hints????
Any hints????
I'll also note that it sounds like you are reading an image from a URL. You can do that directly with the HTTPCaller and there would be no issue of using the SystemCaller.
Anyway, just to mention that you might get a better response if you post this as a new question, rather than a comment on another one.
Hope this helps
Mark
