I was wondering if there is a way to make FME use more CPU? I have workflow with GML Reader and Multiple SQL Server Non-Spatial Writers. Multiple writers are there because I need to insert into identity columns in four different tables parts of transformed GML data.
Here FME is reading GML and writing it into SQL Server by using 10-13% of CPU. How can I make it use e.g. 70-80%? Memory occupied bu FME is also 500-700MB.
How does this work?
Best answer by david_r
