Dear all,
I have a (parent) workflow that uses an Excel file as input. The file contains string values which are used to query an API on the internet. Every record contains a different querystring. The actual calls are made by a workspace which is used as a workspacerunner (see the first image).
In that workspace I have exposed returned fields as attributes (see the second image). The problem I am having is that I expext a number of attributes coming out of the workspacerunner, but I only get two, which are the input attributes of the workspacerunner. How do I make the workspacerunner spit out the right attributes?
Best answer by david_r
